- Apr 23, 2001
Full Article - Overclockers.Com
From The Article "CoolerMaster Aero4" Joe Citarella - 8/12/03
NOTE: This Information Is Edited :- Reading The Full Article Is Recomended
1) What is your opinion of the design of this heatsink ?
2) Does heatsink size concern you, could you fit this it in your case easily ?
3) Do you believe that we will need to re-think the heatsink and fan design in order to cool processors of the future, or will we eventually move away from air cooling completely ?
4) Considering the fan speed, what do you think of the performance of this unit ?
5) Do setups like this offer the consumer something, or is it a situation of design over purpose
6) What are the most important considerations for you when buying a heatsink?
Fan: Adjustable 1900 to 3500 rpm, 11 to 20 cfm; Size: 83 x 70 x 46 mm.
The good guys at Pham Computer were nice enough to send a sample of CoolerMaster's latest P4 heatsink, the Aero4. Included with it is a rheostat which varies fan speeds from "1900 to 3500 rpm"; it includes both a PCI slot and floppy slot cover mount for convenient adjusting.
