24 inch 1080p ips monitor sugestions
carlos515
Hi All,
I am in the market for a new monitor. I have been looking at ips panels . I will watch movies and regular computer activities for now . I am looking at the LG Electronics 24MB35PY-B . But i have not found any reviews for it. Also i am considering the Asus VS239H-P . Any suggestions will be welcome. My budget is $220 Canadian.
Thanks,
Carlos
ATMINSIDE
The Dell U2414H is amazing and meets your requirements. I use three of them for Surround gaming.
RollingThunder
Destroyer of Trolls & Spammers
While the Dell U2414H is an out standing monitor, if you have an older system, there is no DVI or VGA connection. It's also a 6-bit panel color. For the price, it's excellent.
ATMINSIDE
It's a 6-bit with excellent FRC implementation.
I highly doubt any but the most trained of eyes could tell the difference between the U2414H and an 8-bit panel.
RollingThunder
I sit side-by-side with a 6-bit color U2412M and an 8-bit color U2413 and I see the difference. It's not a game changer but I can see it but the price difference is considerable.
C
carlos515
Hi ,
And thanks for the suggestions. The dell is $300 plus tax so it is out of my price range. But i have come across this ViewSonic VG2433SMH . I have not heard of ADS panel. Does anyone have info on it?
Thanks,
Carlos
C
carlos515
Hi JrClocker ,
I have checked out the lg. How are the blacks and is there any glow? Did you need to calibrate it ? I can get the LG 24MP77HM for 20 dollars more which is factory calibrated. I am torn between the 2. I have not bought a monitor since 2008 and a lot has changed.
Thanks,
Carlos
JrClocker
AKA: JrMiyagi
There is a little bit of bleed through, but not much. The blacks are good.
I didn't have to calibrate them, but I'm not a super photo type of guy. I bought the 3 separately over about 3 weeks. They all match color-wise well.
I'm very happy with them.
