It's early and I'm at work, so temper my remarks with the fact that the coffee has not set in after a late night technical session. IE I may be way off in left field. Keep in mind that I'm not a CPU gate-level Engineer.
If you look at the Fab51 approximation of the Multiplier decoding circuitry and assume there is no more complexity (connections) than it portrays. In the arena of "crimes of omission", what could AMD have left off? We know the pull-down resistor is still in the circuit. We know the L3/L1 junctions are physically connected to the appropriate BP_FID pins on the bottom of the CPU. We don't know that the FID Driver register outputs are physically connected to the appropriate FID pins on the bottom, but chances are that they are since if you set the bios for auto-detect, it does come up with an 11x multiplier. We know that in unlocked CPU's, you can change the multiplier by either cutting a bridge or forcing it in the bios. That implies that the combination of the Multiplier control circuitry input pull-up and pull-down resistors, when a bridge is closed, cause a biased logic level zero. By biased, I mean the voltage is not simply a hard short down to zero volts, otherwise the forced logic level from bios coming in on the BP_FID pins could not overide a closed bridge. Stay with me on this... . There's a lot of assumptions coming. Assume that AMD did not isolate the inputs to the Multiplier control circuitry, otherwise we would not see a change in resistance when we changed ohmeter polarity since there would be no semiconductor gating effect, which is assumed to be the reason the resistance changes with metering polarity. What else could be missing? How about the pull-up resistors? What could happen without them? Well, we know that the 1k ohm pull-down resistors would pull down the biased logic level zero voltage at the input to the Multiplier control circuitry even further, perhaps so far that the externally bios forced logic level could not overcome it. A big variable is the question of whether, in the absence of a pull-up resistor, if a bridge is cut, would the load on the path, with the now isolated pull-down resistor missing, be enough to draw down the input so far that even an external, bios forced logic level one would not overcome it? Darn, I lost my train of thought....
Anyway, I'm taking my stereo microscope home for the weekend and armed with a fresh box of x-acto blades, I'm going to cut one of the L3 bridges, micro-solder some 36ga. enameled wire to each side of the bridge as well as one of the uncut bridges on both my unlocked and locked Bartons, then with the CPU in my system, measure what the voltages are in them with the bios set for auto-sense as well as set to force those two BP_PID pins and see what the levels are. If I see the cut bridge on the locked CPU does not pull-up as high as the one on the unlocked CPU, I'll hook up my decade resistance bridge between that line and Vcore and see if an externally supplied pull-up will swing logic level to a one. That's a lot of work and a long stretch, but it would enable us to determine whether the locking could be overcome by simply soldering some fixed value resistors to the bottom of the motherboard on the BP_FID socket pins.
Gotta do my "real" job now. BBL
Hoot
