IBDustin15
- Jan 29, 2013
So I got my chip at 4.5GHz and it is extremely stable. I ran 20 runs on Intel Burn Test on Maximum (71 C Max Temp), and also about 17 hours of Prime 95 (60 C Max Temp).
I am however worried about my Voltage. I am seeing people getting 4.5GHz with less than 3.300 VCore. Mine is obviously much higher.
Here is my BIOS & a screen shot my voltage on Prime 95 Burn:
\MB - ( M.I.T )/
\Advanced Frequency Settings/
CPU CLOCK - 33X
BCLK - ( DISABLED ) left at default 100mhz
EXTREME MEMORY PROFILE XMP - ( PROFILE 1 )
SYSTEM MEMORY MULTI - ( AUTO )
\Advanced Cpu Core Features/
CPU CLOCK RATIO [33X]
PWN FREQUENCY CONTROL [ AUTO ]
INTERNAL CPU OVER CURRENT PROTECTION [ AUTO ]
INTERNAL CPU PLL OVERVOLT [ ENABLED ]
RATIO CHANGES IN OS [ DISABLED ]
INTEL BOOST TECH [ ENABLED ]
RATIO 1 - 4 [ 45 ]
TURBO POWER LIMIT [ 300 ]
CORE CURRENT [ 300 ]
CPU CORES ENABLED [ ALL ]
CPU ENHANCED HALT C1E [ AUTO ]
C3/C6 STATE SUPPORT [ AUTO ]
CPU THERMAL MONITOR [ DISABLED ]
BI-DIRECTIONAL PROCHOT [ AUTO ]
\Advanced Memory/
EXTREME MEMORY PROFILE X.M.P [ PROFILE 1 ]
SYSTEM MEMORY MULTI SPD [ AUTO ]
PERFORMANCE ENHANCE [ STANDARD ]
DRAM TIMING SELECT SPD [ AUTO ]
CHANNEL A - B [ AUTO ]
\Advanced Voltage Settings/
MULTI-STEPS LOAD-LINE [ LEVEL 6 ]
CPU VCORE [ 1.365V ]
QPI/VTT VOLTAGE 1.050V [ 1.20v ]
SYSTEM AGENT VOLTAGE 0.920V [ AUTO ]
DYNAMIC VCORE [ AUTO ]
GRAPHICS DVID [ AUTO ]
CPU PLL VOLTAGE 1.800V [ 1.800V ]
DRAM VOLTAGE 1.500V [ 1.500v ]
DRAM VREF 0.750V [ AUTO ]
DRAM TERMINATION 0.750V [ AUTO ]
CH-A/B ATA VREF 0.750V [ AUTO ]
CH-A/B ADDRESS VREF [ AUTO ]
\Misc Settings/
ISOCHRONOUS SUPPORT [ ENABLED ]
VIRTUALIZATION TECH [ ENABLED ]
\Advanced Bios Settings/
QUICK BOOT - [ DISABLED ]
BOOT LOGO - [ DISABLED ]
\Power Management/
HPET SUPPORT [ ENABLED ]
HPET MODE [ 64BIT ] - 64bit windows versions
\Pc Health/
CPU SMART FAN CONTROL [ DISABLED ]
System Model: Z68XP-UD3P
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz (4 CPUs), ~3.6GHz
Memory: 8192MB RAM G.SKILL Sniper Low Voltage Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Here are my results with my CPU on Prime95 burn test and 100% stable. Can anyone give me some help on how I can get to a lower Voltage?
\MB - ( M.I.T )/
CPU CLOCK - 33X
RATIO 1 - 4 [ 45 ]
\Advanced Memory/
\Misc Settings/
\Power Management/
\Pc Health/
