Trypt
Mississauga, Ontario
my cooling setup..
What would be the most I could o/c on average with my cooling setup and a barton 2500+. I don't have the chip yet, so I can't experiment, which I will do anyway, but I would like some opinions.
Leviathan41
@Home, Folding
If you haven't got it yet, chances are it will be locked. As far as determining a max overclock, like you said you will just have to experiment. But I can tell you it will do (200*11) 2.2GHz pretty easily, even on stock voltage often. You will more than likely be able to push it past that with appropriate cooling, and if your mobo and ram will let you.
Just experiment and let us know what you find. Good luck!
dalilman52
Houston
it mainly depends if it is unlocked or not, check HERE for some info, read around and u should be able to fidn the info u need, yeah the stepping is also another big factor in ur overclock
