266 a problem?
Chris
England, UK
ive got my 900 workin with a 266FSB it seems to work fine and temps seem 2 be fine, but as soon as i play a game after about 10mins the game crashes. I checked the temp after the game had crashed and was at a cpu temp of about 45C which is that bad. Whats the problem? little more vcore? (Im usin 1.85v now)
orangezero
you could also try to lower the voltage if you can. my 900 only needs 1.79 at 9x133. should help with the temps a bit, even if you can only get it down to 1.825
