2800?
c627627
c(n*199780) Senior Member
I don't know what *mem* is but if it's multiplier locked (new ones are) you'll be stuck with 12.5 multiplier.
You may need to underclock your RAM.
If you're unlocked, up the FSB as much as you can with Vdimm voltage up, then up the multiplier. Gradually increase the Vcore voltage.
You know the drill, watch the temps while Prime95 Torture Testing, 2.3 GHz is average, shoot for 2.4 with adequate cooling & PSU.
D
Drak55
Pembroke Pines, Florida
if the chip is locked can it be unlocked?
The Coolest
Senior Member
There are some old 2800+ TbredBs but they are VERY VERY rare, so pretty much every 2800+ is a barton
Hoot
Inactive Moderator
Twin Cities
If it helps ease your concerns until it arrives, a lot of the higher priced Bartons, like the 2800, 3000 and 3200 don't move nearly as fast from inventory of the resellers and chances can be real good that yours will be old enough so as not to be locked. Do post your stepping code when it arrives.
Hoot
stryder2720
Monkeys
I just OCed my 2800+ Barton to 2.215gigs and its ROCK SOLID but i think its locked,so I just bumped my FSB up to 177.ME SO HAPPY:):):) Check Sig.
Idle:28-30c
Load:38-40c
SLK-900A
c627627
Bartons have 512kb cache to T-Bred 256KB.
Your 1700+ has to run 100 Mhz more to match Barton's cache so 1700+ running at 2.3 GHz = Barton at 2.2 GHz.
