- Jul 22, 2013
- Canada
Hello Everyone,
I'm working on a new build for gaming, general use and I'll be using CAD programs occasionally as well (AutoCAD, Civil 3D). I'm replacing my first build, which wasn't exactly top shelf material.
I've learned a lot since then though, and I have plenty of parts that I can reuse for this build. However, I'm a bit uncertain on which CPU and Motherboard to get. I'd prefer to use AMD components to keep costs low, but I'm open to using Intel as well.
I wanted to wait for steamroller, but after hearing that Kaveri has been delayed to 2014, I've decided I can't wait 6 months. If the performance is that much better I'll upgrade again when excavator is released.
I'm planning on overclocking, and would like to get a quality motherboard that will allow me to reach high clocks, and have the flexibility to Crossfire GPUs later on (I want a triple monitor setup down the road).
Currently my setup includes a 23" 1080p LG Flatron W2353V and a 51" 1080p Samsung Plasma, so my gaming resolution is limited to 1080p. I want a graphics card that will get me 60FPS with high quality image settings if possible within my price range.
My current build is LOUD; this time I'm going for a quiet computer for watching movies/less ambient noise. A GPU with a decent cooler is a must - I want to keep the noise down. My case has a 3 speed fan controller and 3 140mm fans. I'm going to be running my cooler in a Push/Pull configuration with 120mm Scythe Slipstream fans (they each have a PCI slot fan controller potentiometer). I have some spare 120mm Blue and Orange LED case fans to spice it up and Y-splitters to connect to the fan controller.
Pretty much everything is covered except my CPU/MOBO and GPU.
Here are the components I have already:
Case: Fractal Design MIDI R2
P/S: Corsair HX750 Professional Series 750W Power Supply
SSD: 60GB OCZ Agility 3 SATA3 (Windows/Priority Programs)
HDD: 2TB Seagate Barracuda SATA3
RAM: 2 x 4GB Corsair Vengeance LP DDR3 2133Mhz 11-11-11-27
Optical Drive: OEM 24x DVD RW Drive
CPU Cooler: CoolIt ECO II Liquid Cooler (OEM Corsair H60)
My price limit for CPU and MOBO is $250-300; I would like to allocate more for a Quality GPU.
I was considering an AMD FX-6300 because of it's low price, decent performance, and high overclockability. Choosing a motherboard is harder though... last time my board only had a 3+1 Power Phase and lacked VRM heatsinks, which limited my overclocks to around 10%. Oops.
As for a GPU, I was looking at the AMD Radeon HD 7950, because overclocked it can take on a 7970 at a lower price. However, unless a good deal comes along, I think it may be wiser to wait for the HD9000 series. My price limit for the GPU is also around 250-$300.
Am I on the right track? Let me know what you think!
