i just got a brand new 3.0c in the mail (newegg retail, sl6wk, pack: 3/16/04, batch: 3405a420, 12 caps) and i was expecting more out of it.
i was running a 2.4c at 2.8 with a 235 fsb at default volts, but this 3.0c is underacheiving.
at default volts it's fine up to about a 215 fsb (runs very cool, 46-48 full).
anything over that with default volts and i get locks and crashes (even though i'm running cool).
at 1.575 volts i can get up to 225 fsb (with a 60 degrees load) but i get crashes with anything higher.
i can get up to about 235 with 1.6 volts, but that runs about 65 degrees full load.
i dont like upping my volts above default levels, but i guess 1.575 is allright. it just makes my temp go up a lot anyways, and i still dont get much out of it.
i thought my troubles mightve been my psu, so i bought a 430 antec truepower to replace my 330 antec truepower and there is no difference.
i was hoping i could get 235 out of this cpu at default vots, but i'm not even close. anyone have any suggestions?
ic7 rev 1.0 (bios 24)
geil platinum 3500 at default latency (4:5)
2x maxtor dmp9 sata raid0
radeon 9800np @ 366/331 (agp voltage at 1.65)
audigy2 zs
2 optical drives
floppy
2 80mm case fans
3 small case fans
zalman CNPS7000A-Cu
audigy2 zs
2 optical drives
floppy
2 80mm case fans
3 small case fans
zalman CNPS7000A-Cu
