- Nov 25, 2003
- SE Pennsylvania
Recently I just acquired myself a porsche Heatercore with 3/4inch inner diameter piping. I thought to myself, 'I can just get adaptors to change it over to 1/2'. But then I thought to myself again 'Can I make my entire system 3/4?' So here I am, asking you guys. I dont have a pump or waterblock yet, I was planning on a eheim 1250 and either a RBX or WW. Could I get myself replacement 3/4 barbs for both the pump and block? Im sure I can for the pump, and the extra diameter in the inlet will be nice to the pump, but I worry about the block. Would I break or hurt or disrupt anything if I take out the stock barbs and put bigger ones in? (Worrying about leaks, or the fact that the barbs might just be set into the block, and wont come out)
Thanks for any help.
Another thing, would two T lines help or hurt my system (im building a external WC case, and two T's would look better, but im wondering about 1) will it hurt performance?, and 2) would it make bleeding go faster? Thanks again.
-Josh
-Josh
