3/8 or 1/2 hose?
CSaddict
CT, USA
I going to start assembling my parts for my water cooling project. I see some using 1/2 inch and some using 3/8. I want to use 3/8 do to its what I have available and I have a ton of it and a ton of 3/8 fittings. My question really is do you guys feel that 3/8 hose will cool adaquitely?
DodgeViper
WILDCAT COUNTRY
I used 1/2" but only because I had already built my rad to use 1/2". I am using a Eheim 1250 pump and Gemini High Volume Block. With this setup it only delivers 60 GPH going through the block, even though the pump is a 317 GPH pump. I have about a 10" rise and this does have an effect on output. Hoot is using 3/8" tubing with nearly the same setup and our C/W is the same.
cyber mouse45
Cyber Cheesiest Senior
SC
Wow, that’s a nice looking setup you have there Dodge. I wish mine looked that clean and open. :D
*edit* Arrgghh!! No fair. I just noticed that your mobo power connector is way up there by your W/B and out of the way and out of sight. Mine is right there by my IDE connectors talking up space and looking ugly. Grrrr
CSaddict
CSaddict
CT, USA
Just curious Viper. Having your radiator there. Does the fan push in or out the front. The reason I ask is because if its pushing out, is cooling the water with warm case air. Or if its pushing in the heat is exhausting into case? Help me understand before I put my rig together.
Silver
Senior Citizen (aka old fart)
Dallas, Georgia
To answer the original question, I am now running a xp1600 at 1.73Ghz 2.2vcore using a maze2 and 3/8 line. It should be noted that I use a bong as well.
DodgeViper
WILDCAT COUNTRY
Customrig, I have a T inline with the T line going to the top of the case. At the end of the line is a fitting with a cap. Just unscrew the cap and fill the water.
CSaddict, Air is being pushed into the case from the front fan. The rear fan is pulling air into the case. Push/Pull format. The two rear fans are exhausting the air out the case. I have a small amount of positive pressure in the case.
Billvill
Glenolden Pa
3/8 hose will work just fine ! I have found that a higher capacidy pump 9 that is a pump with a higher flow rate actually raised my temps by about 5% The theory is that the water moves too fast to absorb all the heat it can. I find a flow rate of about 100 gph is perfect.
!/2 inch hose works great too but you dont need to use it.
Billy
Silver
Dallas, Georgia
Picture this, alot of water coming in (ex: my 3.5"x4.0" block with three inlets and three outlets) on a large piece of metal. This would cool the metal quickly. A small area with a small flow (my maze2 3/8" lines) will cool as well as a large flow over the same area as it is restricted by the passages and the single line in and out. I.e. if the processors heat sink is only 1/2"x 1/2" then whether you poor a gallon or ten gallons on it is irrelevant. It will hit the temperature of the water and stabilize (max potential) with either volume at static heat load. I do not think this applies in pressurized high velocity cases.
