- Mar 24, 2002
- Cleveland, OH
Is there going to be much of a difference b/w using 3/8" silicone tubing and 1/2" silicone tubing? I'll contemplating a Gemini High Flow Spiral block with Eheim 1260 pump. Is the smaller tubing (since Gemini only uses the 3/8" barbs) going to make a difference? Or is it wiser to go with a block that has 1/2" barbs on it so I can use 1/2" silicone tubing?
Thanks,
Xive
Thanks,
Xive
