3 fans
Marco
Did anybody ever try using 3 fans:
1 for the processor
and 2 big ones, 1 to blow air into the cabinet and 1 to blow it out?!?
Does it work fine?
Phil
Senior Member
Bolton, UK
you really should do some reading on this sought of subject, unless this is meant to be a joke, most people who overclock use a setup similar to this, I my self have 3 fans blowing in and 3 blowing out, even people who don't overclock use a setup similar to that which you stated, I still don't know whether ornot to take this as a joke
oc jason
Senior Member
Fayetteville, AR
the majority of people use d multiple fans-im not even overclocking and i got 4-1-120mm sucking from the cpu with a duct. 2-80mm sucking out of the case and from the PS, and a high cfm 90mm blowing on the video card HS to keep the heat down.
Da Whip
Senior Member
Sunny Florida, you can keep the midwest!!
Three fans?? Must be the economy model.
I have 2- 120mmPanaflo 69cfm blowing in (1 in front & 1 on the side towards the CPU and video card)
1- 120mm Panaflo 69cfm on top sucking out
1- Sunon 92mm sucking out below the PSU
2- Sunon 80mm above the PSU sucking out
and the 2 that are in the Enermax 431watt PSU.
