- Feb 18, 2010
Well I present to you, the not yet fully complete true mid tower with a 3 x 120 radiator internally mounted. It took quite a bit of hacking, cutting, and head scratching to make this one work. It was my first case modding adventure. I decided to use this raidmax case that was given to me for fixing a computer for a friend. He was given the case by another friend that bought it and didn't like it. So I figured what the heck it was free anyways.
The radiator is a Swiftec MCR320-QP-K
The pump is a DDC with an XSPC top
The reservoir is a Danger Den DD-RAD
The water block is an EK Supreme Aceteal
I have it setup to get some measurements for the new hard drive mounting box and wire hiding cover. I figured that I would go ahead and share my progress so far. I plan on eventually adding NB and SB water blocks into the loop. I will just leave the graphics cards on air because they don't run too hot.
I used brushed stainless to create the radiator mount/front panel, and I think that I will leave that unpainted (but install aluminum fan covers). I will be constructing the hard drive box and wire hiding panel out of stainless as well, and will probably leave that bare as well. I will be painting the inside of the case black to keep a matching color scheme throughout.
And I know that the wires are a mess currently, and will be addressed (was just slapped together)
-Greg
-Greg
