- Apr 16, 2001
Hi guys,
So I made the jump from my 5700XT to an MSI 3080 Gaming Trio. In many ways I am impressed with this card. But, I am also disappointed.
Specs:
3080 Gaming Trio
Ryzen 1700
16Gb of Ripjaws @ 2400Mhz
Gigabyte B450 Aorus Pro WiFi
WD 970 plus M.2
Corsair 850w
Case side open to make sure temps are not a problem
My card says it boosts to 1815Mhz but Afterburner has reported at 1965Mhz.
My problem is I get nasty frame drops in Fortnite. Like screw it go back to the 5700XT kinda of frame drops.
Fortnite settings @ 1080p:
5700XT - Everything on Epic but shadows are off. DX12 on. I don't remember my motion blur setting. I was getting about 180FPS with drops to about 130-140 and highs bumping into the low 200s.
3080 - Tried everything. I get about 120-180 in MAX FPS. Depends on my settings. But I get drops down to the 30s when I snap the mouse or controller to look around quickly.
5700XT max settings = YaY
3080 at medium settings = choppy
What is impressive? My temps are super low. Even when I get the GPU working at 100% my temps usually stay below 70c on my custom fan curve which keeps it quiet. I had similar results when fan speeds were increased.
Back to my question. Is my 1700 really holding the 3080 back? Why can the 5700XT give me a satisfactory gaming experience with the 1700 but the 3080 goes backwards by quite a bit. I did not expect changing over to the 3080 to give me 300FPS at max settings. But I did expect to be at least as good as the 5700Xt until I upgraded CPU/RAM.
Specs:
3080 Gaming Trio
Ryzen 1700
WD 970 plus M.2
Corsair 850w
