32x64, 16x8, 32x72...?!?!?!
JohnnyTheRed
Brockton MA
What do these numbers mean, with regards to memory?
When looking for RAM, you might come across something to the effect of:
CRUCIAL MICRON 256MB 32x72 PC 2100 DDR RAM
OR
MICRON/MICRON ORGINAL 256MB 32x64 PC2100 DDR RAM, 184-Pin, CL=2.5-Unbuffered 2.5V
What exactly do those numbers mean :/
NookieN
The West
The first number is the number of memory banks (in megs). The second its the width of the memory itself (in bits). So 32x64 is 32*1048576*64 = 2Gbit = 256MB.
If it says 32x72, that means the memory has a parity bit (i.e. has some error checking ability).
Usually these numbers aren't very useful. Occasionally you'll find a motherboard that can't support a certain memory density, but that's rare these days.
