Jarmel
- Aug 22, 2020
I've been looking at two memory kits for my PC, which is a 10900k on Z490 motherboard. I've been wondering which is the overall the best among these two. I've asked in multiple places on the internet and got different answers. Both memory kits are on the QVL list for my motherboard, which is the Maximus XII Hero.
https://www.newegg.com/g-skill-32gb-288-pin-ddr4-sdram/p/N82E16820232895?Item=N82E16820232895
https://www.newegg.com/g-skill-32gb-288-pin-ddr4-sdram/p/N82E16820232675?Item=N82E16820232675
The 3600CL14 has lower first word latency (7.78 compared to 8.5) than the 4000CL17, but it's running at a higher voltage (1.45 compared to 1.35). The 4000CL17 has better bandwidth, but I'm not sure if that's more important than the latency difference in this case. I plan on using these at XMP settings although might do some very light overclocking. Both are Samsung B-Die.
I understand first word latency is more important on AMD than Intel but recent benchmarks seem to show that the Z490 chipset responds well to fast memory.
