3DMark 2001 looping problem
OnDborder
Senior Member
HOT 'n Arizona
I have a question for the Xperts out there.....
When "looping" 3dMark 2001 it crashes after 3 or 4 times around.
I can run SiSoft Sandra Burn in (CPU, CPU multi, and memory ) and SETI continuosly with no problems.
So what do you think?
I am running 3DMark on Raid-on tweaker 5.1 from Humus.
182 on core and memory
I find 3dmark to be a good judge for overclocking success... actually, UT, 3dMark 2000 and 2001 are my tests while overclocking. They seem to accurately determine stability for me. The ONLY time I get crashes is when I'm pushing my PC.
Sound like your system's unstable, overclocked or not.
Pinky (Jul 26, 2001 02:21 p.m.):
I have Crucial cl.2
How do I go about finding the source of instability?
OnDborder (Jul 26, 2001 03:20 p.m.):
I have Crucial cl.2
Most of my instability issues have been with my overclocked memory. I had to set my cas2 RAM to cas3 in order to go above 150fsb. Once I did the CPU started to scream for more!
They sell PC150 RAM for overclocking purposes now, I am considering getting some in a month or two (gotta pay off my recent investments first).
OnDborder (Jul 26, 2001 02:02 p.m.):
this little hack with WPcredit works on the Iwill KK266, but not sure about about your MSI though. Open WPcredit and edit register 55. Change the hex value from 89 to 09 (seventh bit to a zero). I've never heard this working on the MSI though, but it could be worth a shot. Good luck.
**I'm really doubtful this will work now, I didn't notice that you weren't using a Geforce card.**
Josh
Pinky (Jul 26, 2001 08:56 p.m.):
I have Crucial cl.2
Where do you buy that 150mem at?
OnDborder (Jul 26, 2001 10:23 p.m.):
I have Crucial cl.2
just about anyone that deals in memory should have it i got mine from fry's i think www.pcnut.com has it
I have Crucial cl.2
Ok, if you had your choice would you go with the PC 150 or let's say the Abit KG7 with DDR memory, which one wopuld you spend your money on?
DDR vs. SDRAM
sounds like a good discussion topic for the memory thread... hint hint :)
I haven't ventured into the DDR realm yet, other than the GF3 DDR, so I really can't say. I can say that DDR systems tend to perform better in benchmarks, but no real life experience with them keeps me locked in disbelief (I know for sure PC150 RAM would kick a$$).
Actually I did post that on the memory board also.
But I wanted to direct that question to you, it seems you have a pretty good handle on this overclocking stuff.
