3DMark Speed Way Battle: ASUS P9X79 Pro (2011) vs ASUS ROG STRIX X870E-E GAMING WIFI (2024)
FirstEver.eu
Recently, I asked a guy with an identical ASUS TUF GeForce RTX 4070 Ti card to check what result he would get in 3DMark Speed Way.
The difference was that my PC is a 13-year-old platform (ASUS P9X79 Pro) with an 11-year-old Xeon E5-1680 v2, and he had a new Ryzen 7 9800X3D and ASUS ROG Strix X870E-E Gaming WiFi board.
Interestingly, his result was far behind (5848 points), until I had to optimize his system myself, then his PC lost by only 0.5 FPS (6055 points).
3DMark Speed Way results:
My full specs (I know… it is overkill but I like to upgrade this platform)
MB: ASUS P9X79 Pro (NVMe & ReBAR Mod)
CPU: Intel Xeon E5-1680 V2 @ 4.375GHz (1.36V) 35x125MHz
RAM: 32GB (4x8GB) Corsair Vengeance Quad-DDR3 2400@2333MHz CL10
Cooler: Liquid Freezer II 280
GFX: ASUS GeForce RTX 4070 Ti OC @ 3000/12250MHz
PSU: Cooler Master Silent Pro M2 1500W
SSD: Samsung SSD 990 Pro 4TB / Samsung 870 QVO 8TB
HDD: Seagate ST18000NM000J-2TS 18TB
WiFI: Intel BE200 Wi-Fi 7 / Bluetooth 5.4 PCIe Card
Other: USB 3.2 Gen2 10Gbps card
Monitor: ASUS ROG Swift OLED PG48UQ
Logitech: G900 , G915, G27, Z906, G51, Brio, other...
More about my P9X79 Pro ReBAR mod here.
Today I will upgrade my RAM to 4x8GB G.Skill DDR3 PC3-21300 2666MHz TridentX CL12 (12-13-13-35) (2x F3-2666C12D-16GTXD Kits) and I wonder if I will be able to run them in quad mode like the current Corsair Vengeance 2400@2333MHz CL10. I am currently getting over 70.6GB/s and if I could boost it to 2666MHz I should be getting around 80GB/s, and this will be impressive for DDR3.
Cyberpunk 2077: Phantom Liberty (4K Ray-Tracing: Ultra)​
Average FPS 98.62 / Min FPS 89.62 / Max FPS 106.54
If you have any suggestions for optimizing DDR3 memory or BIOS settings, please let us know.
UL's Speedway is not CPU dependent at all. Makes sense the scores are similar. It's also a synthetic benchmark and you'll see larger differences in actual games... especially at 1080/1440p where the CPU matters more (than at 4K). That video you threw in at the end describes as much I'd imagine (did not watch) as there's no way a 10+ year old CPU hangs with a current-gen model at lower resolutions. 8c processor that runs 3-3.9 GHz just can't hang with 5-5.7.
That....... seems like a waste. If I understand right, you're literally not gaining anything. What you gain in the move from 2400->2666, you're losing with the higher CL/timings. Save your money.
Why wouldn't you? Four sticks = quad channel on that platform. So long as they are in the right slots, they'll run quad.
My Xeon is overclocked to 4.375GHz (35x125MHz) and I know that in 1080p and 1440p or lower details the difference can be up to 30-40%, but in the highest details and 4K the games still run decently - for example 100 FPS in Cyberpunk 2077 (RT Ultra).
I noticed a big performance increase after changing the FSB from 100MHz -> 125MHz, therefore my DDR3-2400 only works as DDR3-2333.
With my current setup I was in the top 100 with RTX 4070 Ti, and no one else had such an old setup as me :-D
I thought that by upgrading Quad DDR3-2333 -> DDR3-2666 I could get 0.5 additional FPS.
However, something strange happened... performance on DDR3-2666 dropped drastically by 42-48%!
Corsair Vengeance DDR3-2400@2333 CL10-12-12-31
G.SKILL TridentX DDR3-2666@2666 CL12-13-13-35
After activating the XMP profile on G.SKILL, the processor bus is set to 125MHz and the memory to 2666MHz (2x1333MHz)
I couldn't get them to work on the 100MHz bus (even with a lower clock speed, e.g. 2400MHz).
I thought it was a bug in AIDA64, so I decided to add tests in SiSoft Sandra and Hyper PI.
It seems that Quad-DDR3 does nothing for me in games, because the results in Cyberpunk 2077 and 3DMark Speed Way were almost identical.
Does anyone know why memory performance dropped so much?
Right. I get that, but there's still a glass ceiling on a decade+ processor. I"m not saying to upgrade or anything, just that it exists. So, it's awesome you're getting 100 FPS... but maybe 110-120 is in the cards with a modern system. ;)
lol, maybe. But not something I'd spend a penny on.
Normal. :)
Ok, not 0.5FPS but I need 1.9FPS to get back to Top 100 in 3DMark Speed Way... there are really fast PCs on the list ;)
Update...
I found a review on TechPowerUp and after a few minutes I managed to reach 78GB/s :cool:
