3dmark2001 results
rush
i ran test on 3dmark 2001 on my Asus Geforce 2 GTS on Win98 used official detonator drivers 6.50 i have agp 4x enabled in bios and fast write test result was "2530" i checked other people results are around 5000-8000.
My mobo is Asus a7v and Duron 700 Cpu, 128 ram
any sugestions to what i should do ?
oh yah and i ran default test so i didnt change naything in 3dmark
nt
you may want to try some of the newer drivers ,I use the 10.80's , they seem to be the most stable throughout ,you may also want to try coolbits ,its a registry entry that will let you overclock the card and you can get it from the-ctrl-alt-del web site , I got 2258 at default with a gf 2 mx ,you should be getting alot better
wildone
3dmark 2001 // Default ... 4903
1.1Ghz AMD TB
KT7 ABit Mobo
Hercules Geforce3 64Mb 4.0ns RAM (DET 12.40) (220/500)
Generic 256Mb RAM (PC133 3-2-2)
45Gb IBM Deskstar HDD
Creative SB Live! Platinum
Whats the best GF3 drivers btw? I think my results are weak for a geforce3
rush (Jun 04, 2001 10:19 a.m.):
I guess you're comparing your score with 3dmark2000 scores. No way you could get 5000-8000 3dmark2001 scores with a gf2 gts, unless you got a pentium [email protected].
My computer:
3dmark2000=5330 3dmarks
3dmark2001=2331 3dmarks
Durex 650, 128MB PC133, GeForce 2 MX
4400 in 2k
1800 in 2k1
hehe sory yah i got that now
i was doing 3dmark 2001 testing not 2000 ver.... sorry all
i've gotten about 4000 with a the asus v6600 deluxe. there must be something about the way it's setup or something. 4x won't do anything for you right now. Maybe in the future
