- Jan 24, 2002
Hi. I'm getting a message saying that "the 3D accelerator I hav chosen does not support the display setting combination you have chosen. The settings have been downgraded. The default settings for 3dMark2001 are 1024X768 resolution, 32bit colors,
24/32 bit Z-buffer, compressed textures using DXTC formats 1 and 3".
I already am using 1024x768 resolution and 32 bit colors.
I don't understand the rest.
I'm running a 1.2g AMD Tbird w/ 256meg DDR ram on an ECS mobo. some of the tests are skipped and I end up with a 918 score.
Is this the best my system will do or is there a way for me to get the correct settings to get the maximum score my sytem can get?
my video card is a Nvidia TNT2 Model 64 32meg card.
Is my video card a piece of junk?
my fps only goes up to 25 w/ low detail and only up to 13fps w/ high detail tests.
