- Sep 20, 2010
Hi guys,
I just saw a configuration failed error on one of my disks in a RAID5 array. I'm not exactly sure what that means - if the metadata for the RAID got screwed up on the drive or if the drive is failing. The disk in question is a relatively new (purchased in February or March) WDC Red 2TB drive, so I'm hoping it's not failing.
I'm not actually in front of my server right now, but here's a dump from running tw_cli via putty on the controller in question:
Thanks!
/c0 Driver Version = 5.01.00.046
/c0 Model = 9750-8i
/c0 Available Memory = 488MB
/c0 Firmware Version = FH9X 5.12.00.016
/c0 Bios Version = BE9X 5.11.00.007
/c0 Boot Loader Version = BT9X 6.00.00.003
/c0 Serial Number = SV00505828
/c0 PCB Version = Rev 001
/c0 PCHIP Version = B2
/c0 ACHIP Version = 05000e00
/c0 Controller Phys = 8
/c0 Connections = 4 of 128
/c0 Drives = 4 of 127
/c0 Units = 1 of 127
/c0 Active Drives = 3 of 127
/c0 Active Units = 1 of 32
/c0 Max Drives Per Unit = 32
/c0 Total Optimal Units = 0
/c0 Not Optimal Units = 1
/c0 Disk Spinup Policy = 1
/c0 Spinup Stagger Time Policy (sec) = 1
/c0 Auto-Carving Policy = off
/c0 Auto-Carving Size = 2048 GB
/c0 Auto-Rebuild Policy = on
/c0 Rebuild Mode = Adaptive
/c0 Rebuild Rate = 1
/c0 Verify Mode = Adaptive
/c0 Verify Rate = 1
/c0 Controller Bus Type = PCIe
/c0 Controller Bus Width = 8 lanes
/c0 Controller Bus Speed = 5.0 Gbps/lane
Unit UnitType Status %RCmpl %V/I/M Stripe Size(GB) Cache AVrfy
u0 RAID-5 INITIALIZING - 33% 256K 3725.27 RiW ON
VPort Status Unit Size Type Phy Encl-Slot Model
p0 CFG-OP-FAIL - 1.82 TB SATA 0 - WDC WD20EFRX-68AX9N0
p1 OK u0 1.82 TB SATA 1 - WDC WD2002FAEX-007B
p2 OK u0 1.82 TB SATA 2 - WDC WD20EFRX-68AX9N0
p3 OK u0 1.82 TB SATA 3 - WDC WD20EARX-008FB0
Name OnlineState BBUReady Status Volt Temp Hours LastCapTest
bbu On Yes OK OK OK 121 15-Mar-2013
Thanks!
