4 memory modules with 7600X
madman7
South East Ohio
I have 16 Gig of memory in 2 memory slots and have 2 16 gig of memory ordered. The memory is the same as the other memory. So I'll have a total of 64 gig of ram. This is DDR5 and I will have all 4 memory slots full. Is there any issues running all 4 memory slots with the 7600X? Asrock B650e PG riptide mobo.
It will run slower than you probably expect. The typical max is 5200-5600; sometimes it can be 4000-4800. The motherboard will probably try to run it at 3600-4000. However, you will find out when you start the PC.
Basically you are saying since there 4 modules that they probably won't run at the rated speed even if it's set manually to run at it. I canceled the order and might order 2 32 gig modules.
If you need more RAM, you may also get 2x48GB. 2x48GB works without problems at 6400+ (about the same as 2x32GB). I'm using a 2x48GB Kingston Renegade 6400 CL32 with XMP in AMD and Intel motherboard reviews, and it works without issues on both. Other brands have EXPO kits with about the same specs, but 6000 CL30/32 is perfectly fine and should be cheaper.
Yea my co-worker was complaining about mem speed / issues and sure enough he was running 4 sticks even though when he asked me before buying i said buy 2 Large sticks and stay to 2 sticks.. people really never listen lol.
That said In Canada 48GBx2 kits are almost non existent even now.
