- Dec 18, 2000
- Chapecó-SC
Hey guys, did anyone of you have had problems when enabling memory interleaving? I got random reboots at 4-way plus some random booting failures and the same at 2-way interleaving... And the same setting the ram to 100mhz cas3...!!! (don´t think it´s the overclock) Have anyone got this? And how did you solve the problem if it´s the case....
I think i saw somewhere that the memory interleaving possible to your ram is equal the memory size (128 in the case) divided by the amount of chips in the memory... Don´t know exactly the trick... :-(
----------------System info:--------------------
Mobo: sy6vba133 >(
CPU: celronII [email protected] :*
with generic slotcket ;P
Ram: Generic Nec [email protected] cas3
HD: Seagate barracuda 7200rpm 10.2 Gb
Video: StealthIIIS540 @135/155
Sound: SB pci128 ;p
Modem USR 56K hardw. oem, pci
CDrom: Creative 52x
Case: 300w psu, modded with acrilic and black light, 1x120mm + 3x80mm fans :*
OS: win98 SE
Cooling: Alpha pal6035 (for the nest 2 weeks
Mobo: sy6vba133 >(
Sound: SB pci128 ;p
CDrom: Creative 52x
OS: win98 SE
