will my 430watt true power (duel rail 17a/17a on 12v) run a x1950pro agp ok or should i order a new PS at the same time? really dont want it to get here and not work.
I ran my PCIe X1950 Pro and my E6600 overclocked on a 430W Antec for a bit and it worked, but it was maxed out. I could hear the fans change speed under loads. I bought a bigger PSU with crossfire in mind.
hmm think i might pick up a ocz powerstream 600w off the forums here, i like the gamerXtreme OCZ but from what i can tell 2x of the 4 12v rails are only for pci-e which i dont have, and wont have for a year or so.
With the current setup you shouldn't have an issue to running it on the Antec. Really only way to test is to get it and find out. I mean people have got 1900XT's to run on 350W PSU's before so you'd think it should be possible with that card and rig.
