- Jan 10, 2012
take the vcore off auto and set it to 1.25
Yea, I see that now. Pics weren't showing up at first. That's still insane for a default setting. I think that F9 BIOS needs some work. F9 was released pretty early in the Devil's Canyon game, in fact a few months before it's release. I know the ASUS Z87 BIOS updates to support Devil's Canyon weren't released until the end of may.
Looks like 1.352 LvcoyoteI'm wondering what the BIOS says the CPU voltage is set to?
Mpegger look more closely at the OP's screen shots, it's in the 90's and the Voltage is 1.4+.Guys, stock 4790k with stock Intel cooler with AS5 as well here, just like the OP. VID is about 1.21, fan profile set to keep it high, and my temps are also hitting 70C and higher easily, in 80F room temp. It's normal. Hell, right now I'm idling about 49C.
The temps are less of a concern for me then the voltage, as you are correct that it could be a issue with the program reporting wrong. That said the Cpu-Z being used is the latest version which supports the 4790k chip. It also has reported the voltage correctly for another user I know that has a 4790k. It is also going into the 90's at idle not under load.I saw that initial screen shot. That indeed is high, but I easily hit 90C when running a benchmark as well, and even during gaming, 85C is pretty much normal. Volts tend to be inaccurate in programs till updates have been made, and considering he's using a 4790k in a older board, even the Bios may not completely support it. You are right that he should ensure that he manually sets the VID in bios to ensure correct voltage, but those temps so far seem normal to me for the cooling he has (same as me), although a little on the high side.
