Hello all,
I currently run 2x titanX and a 4790k on a single loop with 2x 240 alphacool rads, 2x corsair SP120 per rad, and a AF140 in the back as exhaust inside a define R5.
I've noticed while gaming with "optimised defualts" in the bios on the CPU my average temperatures are 55-60c on the GPU's and 70-75c on the CPU with the fans running at 12v highest speed via the define R5 built in controller.
I'm semi new to water cooling but I always thought while gaming the GPU being most used would yield highest temps.
Do I have a duff CPU or not enough cooling?
Reservoir is a EKWB D5 variable 240 combo and ambient room is usually about 25c maximum all radiator fans are intakes (Drawing outside air)
Any help or advice would be great, here is the rig setup for reference.
