4GHz here I come!
[AK]Zip
Well I hit 3920MHz stable and will be trying 4GHz+ :) More info on this rig in my sig. (system 1) I am very happy with how this one came out. My last P4 3.2 wouldn't go above 3712MHz regardless of voltage.
-Alex-
@md0Cer
Senior Member
Denver, CO
Excellent job! You are almost high enough to round up to 4GHz. :p
From your signature you have very decent temps for that high a vcore and clockspeed. I calculated your thermal wattage and you roughly have about 165 thermal watts to take care of :eek:
I am no Pentium4 expert, but I have heard they do not take well to higher Vcores, especially not above 1.75, so just warning you that there is a possibility your CPU could develope troubles in the future.
A
[AK]Zip
Sjaak said:
what (in detail) is your cooling system?
Great job :thup:
Swifttech CPU waterblock lapped to 20,000 (mirror finish) along with a swifttech northbrige block lapped to 2,500. I have the swifttech pump and I have a custom built radiator with 2 120mm fans on it rated at 17db each. I will be adding a waterblock to the GBU once DD releases one for the 6800 series cards.
-Alex-
aNTiChRisT
England
I feel that chip will die... older chips were good to no more than 1.7v on water -- some newer chips are even more temperamental...
Note its an asus board, i really suggest an external temp monitor... even manual to gauge it. If it is warm its about 30c, warm/hot 40c and hot 50c
Regardless of temperature, i wouldnt consider running a CPU at that with anything BUT phase -- and even then not for 24/7 usage.
I remember reading something from intel, 1.7v+ requires a temperature of 5, or -5 (i cant remember) or less...
~t0m
hUMANbEATbOX
Contributing Member
if its taking you 1.75 to get 3.9, i'd say 4 is well out of your reach, IF you want a safe long lasting OC.
i would drop it to 3.8 at 1.65 and be happy.
Cerberus2k7
Drifto Mexicano
Morris, IL
I say get some vapo ^_^ Then at least you can have the bragging rights, even if you do have to back it back down.
A
[AK]Zip
The CPU itself won't let me boot above 1.8v and Ive gone up to 246X16 now at the same voltage. I will just see how high I can go stable at 1.78V and just leave it at that. My friend has a 2.8 running at 1.8v on water and has for many years now so I am not worried about it dying on me. As far as tems not being correct trust me they are. I had a seperate temp probe inserted and it was preaty much the same temp (+ or -1*c) I didn't think that my temp was going to be this low, but it is. Also just to compair. My temps at 1.6v were 27*C idle and 30*C load and thats with room temp of 22*C.
-Alex-
A
[AK]Zip
I just wanted to let everyone know that 3920 was as high as I could go 100% prime stable at anything below 1.8V. I will be staying at 3920MHz at 1.78V. Ohh well not too bad for a 100% silent computer. Ohh well back to building my custom speaker boxes for my speakers.
-Alex-
ShaftedTwice
San Diego, CA
-Alex-
Not a bad machine.. super fast, super quiet. I still cant see how it could be so quiet tho.. how many fans you got on your case?
A
[AK]Zip
The loudest fan in my entire computer right now is from my 6800GT oc. I am not even sure what the fan is rated at. My 2 radiator fan (not in push/pull config) are 17db each. Then I have 3 case fans which are set to medium which are 16db each. My PSU case fan is 23db which was replaced with a 16db fan. I have no CPU fan or NB since both are watercooled. Before my 6800gt my computer was preaty much 100% silent. Only a slight buzz was herd when sitting next to it, but when I go to sleep I couldn't hear it at all and im very sensative to sound. As soon as a waterblock will be releaseed for the 6800 cards I will be buying one so I can finally leave my computer on at night again.
-Alex-
A
[AK]Zip
No joke man. Its crazy. I hate the sound of fans. Im cursed. LOL
-Alex-
A
[AK]Zip
ShaftedTwice said:
Anyways, how much did that cooling system cost altogether?
If that directed to me then. The CPU block was $40, the northbridge was $35, pump was $65, radiator didn't cost anything because I made it. So $140. :)
A
[AK]Zip
1-Man-Army said:
got any pics :D of the w/c setup...
Yes I will get one up.
k_r_i_p_l_e_r said:
how does this machine run ? boot up in 5 sec ? lol is there that much of a diff from [email protected] stock ?
Well everything loads a whole bunch faster especially games and that sort of thing. I don't think my video is limited at all either unless if at 800X600. :)
