4GHZ OC adding 4 GIG of ram making unstable?
zazzn
Bay area
Hi guys,
I'm not new to overclocking, been doing it since my P133 days ;)
Anyhow, i've come across the strangest thing. I've added 4more gigs of G skill 2000MHZ trident ram but my machine becomes completely un-bootable when both kits in. I've booted successfully with both kits separately and the system has been prime 95 stable for my 3-4 HR test. So I'm not quite sure what is going on with the memory because both work it's just when it's in the board together nothing works as I expect. Any ideas?
Neuromancer
Tau'ri
Give a bump to your northbridge voltage or lower memory speed.
LOL I did not notice this was a p55 setup.
Same thing though bump "northbridge" voltage :) VTT/QPI PLL.
redduc900
Inactive Moderator
Portland, OR
Besides the DDR3-2000MHz RAM, list the rest of your system spec's including the QPI/VTT voltage at the current 10x DRAM multiplier.
Z
zazzn
Bay area
Thanks guys I'll try upping it...
My comp specs are
P55 UD2 (gigabyte)
8GIG Gskill Trident 2000MHZ
I5 570
PC power and cooling 610 W psu
Radeon 5870 vid card
Running 4.0GHZ @ 200 ram @ 2000 MHZ 1.375 Volts.
1 WD 1TB black edition - win 7 on this.
1 Seagate 7200 1TB drive - win xp on this
Rich'[ard]
Melb, AUS
loll, funny enough i was just about to post the exact same thing...until i realised this was a socket 1366/1156 section post...:bang head:
