I wrote quite article on this matter about a week back, since i cant seem to get the proper link to that thread i will just post it here.
Well at first glance it should be an obivous answer, configuration B, but I am not so sure that there is that much of a difference. Because, when you run a system at 133 Mhz the PCI bus automatically changes to 1/4 of the the front side bus which would equal to 33 Mhz. When it is at 100 Mhz then it runs at 1/3 of the front side bus which is alco equal to 33 Mhz. So If all of the components in your computer are remaining at the same speed then what are we gaining by increasing the front side bus. Well as far as I know the only difference is that the ram. In a 100 Mhz fsb motherboard the ram can be set to equal the front side bus + the pci bus speed. In an unoverclocked system that would be 133 Mhz. That is the same speed that the ram runs at in a 133 Mhz speed except that since it is running at the same speed as the fsb no bottlenecks occur. On the otherhand by having a system running at a speed of 133 Mhz it would take increasements of 4 Mhz for every 1 Mhz in PCI bus speed increase. Therefore assuming that a 133 Mhz system and a 100 Mhz system could both overclock over their default values at equal amounts then the PCI bus would be faster on the 100 Mhz system. Example. If you ran a 100 Mhz system at 112 Mhz then the PCI bus would be 37 Mhz. If you ran a 133 Mhz system at 145 Mhz then the PCI bus would be at 36 Mhz. While this is not a very large difference in speed it is some. So lets recap. In a 133 Mhz system the advantage is less bottlenecks in memory. The disadvantage is slightly less PCI bus speed. And vis-versa is true for a 100 Mhz system. So who is the winner. Well I believe the advantage goes to the 133 Mhz for two reasons. The first is the added memory speeds out weighs the slight disadvante in PCI bus speeds and Most 133 Mhz chipsets can overclock better than 100 Mhz chipsets. The VIA KT133 and VIA KT133A chipsets for example. Most KT133's max out at around 112 while I believe that most KT133A chipsets can do around 150, but I am not sure about that. So my conclusion is that while the 133 Mhz front side bus speeds are better than the 100 Mhz front side bus speeds there is not as much difference as you would think. Does Anyone have a link to benchmarks of identical systems except one having a VIA KT133 chipset and the other having a VIA KT133A chipset? This would show the real difference.
So by changing the divisor to 5 i think performance increase wont be as much as it could be. Although 165 Mhz memory is very impressive.
