It's significantly lower, but we didn't end up using a current probe on the samples we had due to cost. They simply didn't make the RFA due to the cost.
From the spec sheets on the C4K40, the drive should pull around 420mA on startup. By comparison, the 5K100(relatively power efficient) will pull around 1000A on start.
Interface boards can vary widely due to components and parasitic load. Most RoHs solutions tend to use more efficient chipsets. Expect loads in the 100-200mA range for most units.
Personally, I'd stay away from the 1.8" drives due to the extreme lack of performance in the first couple of generations that we looked at. STR and access times were simply abysmal and the costs were truely abhorrent.
Of the retail enclosures that we looked at, the Vantec Nexstar wasn't bad. The Sabrent seemed underengineered and occasionally had issues with power on a single cable with larger drives. Both were not the caliber we were accustomed to, but would do for occasional use.
