Another rookie question. I am planning out my loop in a SFF (Sliger sm570) and I have an Alphacool 50mm (100mL) tube reservoir which can fit between the GPU and front panel. Problem is that the mounting brackets that come with the res are huge (relatively speaking) and do not allow me to mount the res anywhere in the case.
I have 2 questions:
1. can i mount the res in that location using velcro? I could use velcro on the back side of the PSU and also on the front panel so that it would be secured in 2 spots
2. does anyone know of any 50mm res mounts that are low profile? I have a total of 60mm to work with, so there is only 10mm of total clearance for a bracket or mount.
The brackets that came with the Alphacool are roughly 24mm in height.
I have 2 questions:
