512MB Gecube X1900XTX - I'm back
eva2000
Brisbane, Australia
Yes i'm back and you get to watch me continuously post benchmarks with my new toy :D :woot:
I couldn't wait for Gecube to provide me with my X1900XTX/XT Crossfire cards for my testing on DFI CFX3200-DR http://i4memory.com/cfx3200dr/ so decided to fork out for half the setup myself, in the form of a 512MB Gecube X1900XTX card :)
The card arrived yesterday but since i have the flu and bad cough keeping me up at night :( I thought I'd give the card a whirl :D
System:
WinXP Pro SP2 fully updated
6.70WHQL Chipset drivers
6.5 Catalyst Official drivers
Right now stock heatsink air cooled with fan speed at 100% I managed on GPU core using ATI Tool 0.24 beta 14.
GPU Overclocking
1.175v = 655mhz
1.400v = 684mhz
1.425v = 702mhz
1.450v = 712mhz
1.450v = 720mhz with ~63C load temps as monitored via Rivatuner RC16.
1.500V = 725mhz with ~66C load temps as monitored via Rivatuner RC16.
1.500V = 729mhz with ~66C load temps as monitored via Rivatuner RC16.
Here's one of my first 3dmark05 runs with ATI Tool and Rivatuner RC16 running in background.
Video Memory Overclocking
As to memory clocking, seems like my 512MB HIS X1800XT, part of the puzzle is GPU voltage, as you increase GPU volts, mem clocks higher at some point. Here it seems to be at 1.525v GPU volts.
GPU/VDDC/VDDQ/VDDCI = GPU/Mem
Note: PASSED means ATI TOOL continued to run at that stated speed only.
1.500v/2.086/2.086/1.486v = 725/801-805.5mhz PASSED
1.525v/2.086/2.086/1.486v = 725/810-814mhz PASSED
1.525v/2.168/2.086/1.486v = Locked up in ATI Tool at 725/814mhz heat up phase
1.525v/2.135/2.006/1.486v = Locked up in ATI Tool at 725/814mhz heat up phase
1.525v/2.140/2.121/1.486v = Locked up in ATI Tool at 725/814mhz heat up phase
1.525v/2.105/2.102/1.510v = Artifacts at 725/850-855mhz
1.525v/2.113/2.102/1.510v = Locked up in ATI Tool at 725/814mhz heat up phase
1.525v/2.121/2.102/1.510v = Locked up in ATI Tool at 725/814mhz heat up phase
1.525v/2.113/2.102/1.510v = PASSED dropping GPU by 5mhz = 720/846mhz
1.500v/2.113/2.102/1.510v = Locked up in ATI Tool at 720/823mhz heat up phase
1.500v/2.113/2.102/1.493v = Artifacts at 720/846-850mhz
1.500v/2.119/2.108/1.493v = Locked up in ATI Tool at 720/814mhz heat up phase
1.525v/2.113/2.102/1.493v = Artifacts at 720/837mhz
1.525v/2.113/2.102/1.510v = Locked up in ATI Tool at 720/859mhz heat up phase
1.525v/2.116/2.105/1.524v = Locked up in ATI Tool at 720/855mhz heat up phase
1.525v/2.119/2.105/1.510v = PASSED at 720/846mhz
1.525v/2.119/2.105/1.540v = Locked up in ATI Tool at 720/868mhz scanning artifact stage
1.525v/2.119/2.105/1.563v = PASSED at 720/855mhz load temp 75C
Haven't found the max yet for GPU or Mem, but at this point it seems the memory needs more GPU voltage to clock higher than 801-805mhz.
Seems for 3dmark05 at least 720/850 is achievable with 1.525/2.119/2.105/1.563 with load temps of ~67-75C.
3dmark05 = 13,885
http://service.futuremark.com/compare?3dm05=2077846
While Rivatuner RC16 and ATI Tool were running in background.
@720/850 - 13,885 http://service.futuremark.com/compare?3dm05=2077846
@720/850 - 43,894 http://service.futuremark.com/compare?2k1=8998288
@720/850 - 6,962 http://service.futuremark.com/compare?3dm06=353082
Doesn't seem to be the best clocker, but not bad at all :D
You should wc those graphics cards. That would be an awesome set up but it already is really nice so I too would like to see a pic!
Hmm...something is wrong with those results.
I think you should send me that card so I can verify your results, in the name of science of course ;)
thanks
had to go to air cooling on FX-60 to check if my cpu was okay after condensation on phase....
FX-60 @2940mhz 1.408v on stock heatsink air with X1900XTX @650/774 on stock hsf air too and rivatuner, mbm5 and ati tool running in background :)
will be back on phase soon heh
I had to remount my FX-60 after condensation issues and looks like board and cpu are fine.
I jumped to 16x213HTT = 3408Mhz for some 3dmark benching.
I have found that VDDCI voltage is the key to memory clocks on my X1900XTX. VDDCI of 1.563v allows me to jump from 805mhz to 850mhz easily. I can now lower GPU volts and get ATI Tool to past the 814mhz lock up barrier above.
1.425/2.119v/2.105/1.563 = PASSED running scanning artifacts fine at 855mhz on memory.
I can now do 720/850 at 1.5/2.121/2.105/1.563 with 71C load temps instead of 1.525v on GPU core.
Broke 14k 3dmark05 :)
Broke 7k 3dmark06 :D
thanks traldan
Further voltage testing updates
1.525/2.138v/2.009/1.564 = FAILED went up to 720/864-868mhz on memory before blanking out. Seems VDDQ can be lowered without too much detriment to mem clocks, wonder if raising VDDC only will get me higher :)
1.525/2.151v/2.015/1.564 = PASSED 720/864 ran scanning artifact fine. So it seems keeping VDDQ low is fine and just up VDDC :)
1.525/2.165v/2.015/1.564 = FAILED up to 720/868 and failed in heat up phase with 868mhz memory.. getting there though :)
1.525/2.176v/2.031/1.564 = FAILED up to 720/868 and failed in heat up phase with 868mhz memory
1.525/2.181v/2.020/1.564 = FAILED up to 720/868 and failed with 868mhz memory with 16 seconds left to completion in heat up phase!
1.525/2.192v/2.020/1.566 = FAILED up to 720/868 and failed with 868mhz memory with 9 seconds left to completion in heat up phase!
1.525/2.203v/2.020/1.564 = FAILED up to 720/868 and failed with 868mhz memory with 8 seconds left to completion in heat up phase!
1.525/2.203v/2.015/1.564 = FAILED up to 720/868 and failed with 868mhz memory with 15 seconds left to completion in heat up phase!
1.500/2.209v/2.020/1.564 = FAILED up to 720/868 and failed with 868mhz memory with 24 seconds left to completion in heat up phase!
1.550/2.203v/2.020/1.564 = FAILED locked up at 792mhz on mem.. guess 1.550v GPU volt too much for it on air cooling ?? Or maybe with 1.550v i can reduce VDDC volts ?
1.550/2.184v/2.020/1.564 = FAILED got up to 877mhz highest so far, after passing heat up phase at 868mhz, but artifact detecting knocked it back from 877mhz to 873mhz back to 868mhz :)
1.550/2.195v/2.023/1.564 = PASSED 720/868 - even passed heatup phase @873mhz on memory, then ran artifact scanning for 90 seconds before artifact detecting bumped it to 868mhz :D
Getting there hehe
Update: For now settled on 720/864 with 1.550/2.195v/2.023/1.564 - backing off on the mem a notch just for safe measure. 3Dmark05 ran perfectly fine at this speed.
3dmark05 = 14,028 with ATI Tool, Rivatuner RC16 both running in background logging temps.
3dmark2003 = 22,583
3dmark06 = 7,025
3dmark2001 = 44,974
AM3 = 124,159
Pretty happy that I managed to get the vid memory clock up from what seemed like a 814mhz wall in ATI Tool 0.25 beta 14 to the 864-868mhz speeds now on stock hsf air. GPU clocks do seem low at 720mhz but guess nothing that better cooling on GPU wouldn't help fix
do you find the cat 6.5 drivers the best to use? Id heard the cat 6.3 were currently most reliable? its just im trying to figure what drivers I need for when my card arrive later!
cheers eva - ace results :D
thanks.. only tried 6.5 nothing else so nothing to compare against hehes
Moral of the story is don't always listen to ATI Tool. I decided to see if i could clock GPU a tad higher with 3dmark06 instead of what ATI Tool said my core limit was at 720mhz at 1.55v on stock hsf air.
Guess what 725mhz and 729mhz ran fine, but 729mhz resulted in 100pts less in 3dmark06. 725mhz was perfect. I backed the mem clock down from 864mhz to 860mhz for a trial run @725/860 and this is the result :)
3dmark06 = 7,074
http://service.futuremark.com/compare?3dm06=356629
Not bad for stock hsf air :)
Managed 738/868 for 3dmark05 and 3dmark2001 at 1.575v/2.195/2.023/1.564 but it froze in GT1 in 3dmark06, so 732/868 seems like the stable point on stock hsf so far.
3dmark05 = 14,264
http://service.futuremark.com/compare?3dm05=2083234
3dmark2001 = 45,404
http://service.futuremark.com/compare?2k1=9000571
First FX-60 benchmark beyond my cpu's cold bug/low HTT bug. Work around using toast app to keep cpu loaded when idle.
FX-60 @15x229HTT with 233 upclock and 2x 512MB OCZ PC3200 Gold UTT BH-5 @264mhz 2-2-2-5 :)
3dmark2001 = 46,083 :cool:
http://service.futuremark.com/compare?2k1=9000607
H20 cooling results
Yup slapped on Dangerden Acetal Maze4 Low Profile water block for water cooling to see how it goes. With ~23C room ambient, X1900XTX on water cooling
@500/594 2D stock volts = GPU is 31C idle and 36C load
@650/774 3D 1.425v = GPU is 33C idle and 40C load
GPU core clock tests with mem set to always 774mhz
1.425v/2.086/2.086/1.486v = 732mhz on GPU core an improvement of 30mhz over stock hsf air
1.450v/2.086/2.086/1.486v = 733mhz on GPU core with load temps of 40C. Sounds like similar issue with stock hsf air, GPU volts or temps aren't the problem but maybe VDDCI volts ? An improvement of 13mhz over stock hsf air.
1.500v/2.086/2.086/1.486v = 759mhz on GPU core with load temps of 42.5C. Now we're getting somewhere :D
1.525v/2.086/2.086/1.486v = 766mhz on GPU core with load temps of 42.5C.
1.550v/2.086/2.086/1.486v = 769mhz on GPU core with load temps of 42.5C.
1.575v/2.086/2.086/1.486v = 769mhz on GPU core with load temps of 42.5C.
1.500v/2.086/2.086/1.564v = 760mhz on GPU core with load temps of 42.5C.
1.575v/2.195/2.023/1.564v = 769mhz on GPU core with load temps of 42.5C. Have i hit a limit here ? On stock hsf air ATI Tool said my max was 720mhz on GPU but i could bench all the way to 732-738mhz on GPU.
Video memory clock tests with GPU set to always 732mhz
1.575v/2.195/2.023/1.564v = FAILED - upto 886mhz before artifact scanning dropped it to 882mhz.
1.575v/2.225/2.023/1.564v = FAILED - upto 900mhz before ATI Tool locked up during artifact scanning. Load temp = 43C
1.575v/2.266/2.023/1.564v = FAILED - upto 904mhz before artifact scanning dropped it to 900mhz.
1.575v/2.296/2.023/1.564v = FAILED - upto 895mhz before artifact scanning dropped it to 891mhz.
1.575v/2.288/2.023/1.564v = FAILED - upto 922mhz then locked up with slight artifacts.
1.575v/2.280/2.023/1.564v = FAILED - upto 882mhz before artifact scanning dropped it to 841mhz :confused:
1.575v/2.305/2.023/1.564v = FAILED - locked up at 871mhz
1.575v/2.288/1.985/1.564v = FAILED - upto 909mhz before artifact scanning dropped it to 900mhz
1.575v/2.288/2.023/1.533v = FAILED - upto 873mhz then artifacts. Guess VDDCI voltage still is important for mem clocks on water cooling.
1.575v/2.288/2.023/1.575v = FAILED - upto 900mhz then locked up
1.575v/2.288/2.135/1.564v = FAILED - upto 909mhz before artifact scanning dropped it to 900mhz then down to 891mhz
1.575v/2.288/1.935/1.564v = FAILED - upto 886mhz then artifacts
1.575v/2.288/2.047/1.564v = FAILED - upto 909mhz before artifact scanning dropped it to 900mhz then down to 891mhz. Similar behaviour as when VDDQ was at 2.135v
1.575v/2.288/2.015/1.564v = FAILED - upto 913mhz before locking up
1.575v/2.288/2.012/1.564v = FAILED - upto 909mhz before artifact scanning dropped it to 900mhz then locking up
Hmmm not happy with GPU clocks, might need to do a remount of the Maze4 waterblock to see if i can improve it somewhat heh.
Kind of mediocre score huh ? From that i'd probably need 800Mhz on GPU to hit 15k in 3dmark05 LOL
3dmark06 looks better though = 7,338 http://service.futuremark.com/compare?3dm06=358600
Update: remounted Maze4 LP GPU waterblock to see if i could get better contact and higher clocks. Seems to have helped so far.
1.425v/2.086/2.086/1.486v = 739mhz on GPU core an improvement of 37mhz over stock hsf air and 7mhz improvement over first GPU waterblock mount :cool:
1.500v/2.086/2.086/1.486v = 759mhz on GPU core with load temps of 42C. Same max as first mount.
1.550v/2.086/2.086/1.486v = 769mhz on GPU core with load temps of 42C. Same max as first mount.
Got a bit tired of ATI Tool, so thought i'd do 3dmark05 continuous loop tests instead :)
1.575v/2.086/2.086/1.486v = PASSED at 772mhz looping 3dmark05 artifact free! Guess ATI Tool doesn't tell the whole picture :)
well seems ended up around 765mhz gpu core is max when mem is >882mhz, can do 772mhz gpu core when mem is around 774mhz heh
I settled on 765/891 for now. Bit disappointed as i was hoping for at least 785-795mhz GPU on water.
Max load temp was 43.68C or there abouts, never hits 44C so far in 23-25C room ambients :)
Interesting finding, i changed to my other PCI-E power connector on my 1KW PCP&C SLI psu, and now at same 1.575v ATI Tool managed to get to 778mhz instead of 769mhz!
Oh and piccies
edit: darn 778mhz gpu clock was a once off fluke it seems, still 765-769mhz is max sigh
