5750....
ciku
I'm looking for a decent card to run with my new system. I was looking at 4850/4870/4890. Was confused which one to get. Then I check the price for 5750 and they are only around $150... Should I go for 5750? is it more powerful than 4850/4870/4890?
Was looking at SAPPHIRE 100284L Radeon HD 5750 1GB 128-bit GDDR5
Flurp
Washington
significantly better? no... better? depends on what you want to use it for... what exactly are you looking to use it for?
but if those 4 are your choices... and you are goin by performance not the dx11 or integrated audio etc... 4890 > 4870 > 5750 > 4850
just my opinion...
ciku
ciku
This system will be mainly for photoshop, video encoding and playing wow only.
- AMD Athlon II x4 630
- ASUS M4A785TD-M EVO
- Sony Optiarc 24X DVD/CD Black SATA Model AD-7240S-0B
- COOLER MASTER HAF 922 RC-922M-KKN1-GP ATX Mid Tower Computer Case
- Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA 3.0Gb/s 3.5
- SAPPHIRE 100284L Radeon HD 5750 1GB 128-bit GDDR5 PCI Express 2.0 x16
- OCZ ModXStream Pro OCZ600MXSP 600W ATX12V V2.2 / EPS12V - Retail
- G.SKILL 4GB DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model F3-10666CL8D-4GBHK - Retail
what do you guys think?
ciku
ciku
depending on your settings for WoW i's get a better card that 5750... imo at least...
5750 is comparable at least to 4850/4870? it should run at full settings...
