- Apr 12, 2014
Cool, so your all set then,
post some pics of the build, gotta see this come together.
how's your benching going ?
Doesn't need it.
Hmm, I just haven't had a board without it since my Asus P6X5D-E, and most the other x99's have it. But oh well. Its ordered now.
It only comes into to play if you are really pounding on multi GPU set up's
By this he means that you're pulling more wattage than the PCIe connectors from your PSU can supply to the GPU, causing it to pull from the motherboard.
And the PCIe slots on the motherboard are rated up to 75W each.
So you'd need to pull some SERIOUS power to even need extra power to the board.
If you were having vrm temp problems with waterblocks, i can think of worse ways to spend ten bucks than on fujipoly thermal pads to replace the stock stuff. Not sure how good the stuff from heatkiller blocks is, but the fujipoly beat the ek thermal pads that came with my blocks by 8-10c. Also, the vrms are the heat source of the power section.
You're literally wasting money on your e-penis.
This or get a PLX board like he is considering in his other thread (I want to merge the threads since this is essentially the same discussion).....
