Well, i spoke too fast... just got system service exception bsod.
Went back to my 4.6 profile / 1.2v.
Any clue in the report that could indicate the issue?
On Tue 01/06/2021 13:37:39 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\060121-12718-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x3F6CF0)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80356B13B50, 0xFFFFC08598466960, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: dxgkrnl.sys (dxgkrnl+0xA3BD)
file path: C:\Windows\system32\drivers\dxgkrnl.sys
description: DirectX Graphics Kernel
The crash took place in a Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
