I'm building a new rig after 6-7 years and this A-RGB craze has got me confused with how to setup. Seems like there's no standard and every mobo vendor is different.
My mobo is the asus strix x570-f with 2 A-RGB headers and 2 chassis fan headers (can also use CPU_OPT and M.2_FAN). Each fan header is 1A max.
I plan to connect 6 PWM case fans - 3 in front, 2 top, 1 back. I'll need 3 Y-splitters to connect the fans so that's fine, a fan header can easily support 2 fans.
However I only have 2 A-RGB fans. I know A-RGB splitters exist but I can't for the life of me find out how many fans I could safely connect to 1 header. The header is rated at 3A/5V. Would I be safe getting 2 1 to 4 way splitters like this: https://www.overclockers.co.uk/ek-water-blocks-ek-rgb-4-way-splitter-cable-wc-9ly-ek.html, connecting it to each header and connecting 3 fans to each? This would then leave 2 more slots for my GPU/CPU cooler and LED strips in the future.
Any advice is appreciated. For context I'd use either the case fans that come with the Phanteks P400A Digital, or the Lian-Li Bora's, or maybe corsair's ones.
Cheers.
Cheers.
