- Apr 29, 2002
OK this thing has tied up my Q6600 for 4 days and has another 4 days until it is complete.
I thought it was a bad WU, but it can't be killed. Delete all the ID/work files and like a system file it just resurrects itself again and picks up where it left off.
I can barely afford the juice the processor uses doing 7kPPD. There's no way I can justify it for <500PPD if it's one in a whole string of WUs that Stanford usually hands out once you start a series.
Code:
*********************** Log Started 2014-09-05T03:27:22Z ***********************
03:27:22:************************* Folding@home Client *************************
03:27:22: Website: http://folding.stanford.edu/
03:27:22: Copyright: (c) 2009-2012 Stanford University
03:27:22: Author: Joseph Coffland <[email protected]>
03:27:22: Args: --lifeline 23258 --command-port=36330
03:27:22: Config: /home/audioaficionado/.FAHClient/config.xml
03:27:22:******************************** Build ********************************
03:27:22: Version: 7.1.52
03:27:22: Date: Mar 20 2012
03:27:22: Time: 13:19:11
03:27:22: SVN Rev: 3515
03:27:22: Branch: fah/trunk/client
03:27:22: Compiler: GNU 4.6.2
03:27:22: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
03:27:22: -fno-unsafe-math-optimizations -msse2
03:27:22: Platform: linux2 3.2.0-1-amd64
03:27:22: Bits: 64
03:27:22: Mode: Release
03:27:22:******************************* System ********************************
03:27:22: CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
03:27:22: CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
03:27:22: CPUs: 4
03:27:22: Memory: 1.96GiB
03:27:22:Free Memory: 774.76MiB
03:27:22: Threads: POSIX_THREADS
03:27:22: On Battery: false
03:27:22: UTC offset: -7
03:27:22: PID: 23263
03:27:22: CWD: /home/audioaficionado/.FAHClient
03:27:22: OS: Linux 3.11-2-amd64 x86_64
03:27:22: OS Arch: AMD64
03:27:22: GPUs: 0
03:27:22: CUDA: Not detected
03:27:22:***********************************************************************
03:27:22:Started thread 1 on PID 23263
03:27:22:<config>
03:27:22: <!-- Client Control -->
03:27:22: <cycle-rate v='4'/>
03:27:22: <cycles v='-1'/>
03:27:22: <data-directory v='.'/>
03:27:22: <disable-project-lookup v='false'/>
03:27:22: <exec-directory v='/usr/bin'/>
03:27:22: <exit-when-done v='false'/>
03:27:22: <threads v='4'/>
03:27:22:
03:27:22: <!-- Configuration -->
03:27:22: <config-rotate v='true'/>
03:27:22: <config-rotate-dir v='configs'/>
03:27:22: <config-rotate-max v='16'/>
03:27:22:
03:27:22: <!-- Debugging -->
03:27:22: <assignment-servers>
03:27:22: assign3.stanford.edu:8080 assign4.stanford.edu:80
03:27:22: </assignment-servers>
03:27:22: <capture-directory v='capture'/>
03:27:22: <capture-sockets v='false'/>
03:27:22: <debug-sockets v='false'/>
03:27:22: <exception-locations v='true'/>
03:27:22: <gpu-assignment-servers>
03:27:22: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
03:27:22: </gpu-assignment-servers>
03:27:22: <stack-traces v='false'/>
03:27:22:
03:27:22: <!-- Error Handling -->
03:27:22: <max-slot-errors v='5'/>
03:27:22: <max-unit-errors v='5'/>
03:27:22:
03:27:22: <!-- FahCore Control -->
03:27:22: <checkpoint v='15'/>
03:27:22: <core-dir v='cores'/>
03:27:22: <core-priority v='idle'/>
03:27:22: <cpu-affinity v='false'/>
03:27:22: <cpu-usage v='100'/>
03:27:22: <no-assembly v='false'/>
03:27:22:
03:27:22: <!-- Folding Slot Configuration -->
03:27:22: <client-subtype v='LINUX'/>
03:27:22: <client-type v='normal'/>
03:27:22: <cpu-species v='X86_PENTIUM_II'/>
03:27:22: <cpu-type v='AMD64'/>
03:27:22: <cpus v='-1'/>
03:27:22: <cuda-index v='0'/>
03:27:22: <gpu v='false'/>
03:27:22: <gpu-usage v='100'/>
03:27:22: <max-packet-size v='normal'/>
03:27:22: <opencl-index v='0'/>
03:27:22: <os-species v='UNKNOWN'/>
03:27:22: <os-type v='LINUX'/>
03:27:22: <project-key v='0'/>
03:27:22: <smp v='true'/>
03:27:22:
03:27:22: <!-- Logging -->
03:27:22: <log v='log.txt'/>
03:27:22: <log-color v='true'/>
03:27:22: <log-crlf v='false'/>
03:27:22: <log-date v='false'/>
03:27:22: <log-date-periodically v='21600'/>
03:27:22: <log-debug v='true'/>
03:27:22: <log-domain v='false'/>
03:27:22: <log-header v='true'/>
03:27:22: <log-level v='true'/>
03:27:22: <log-no-info-header v='true'/>
03:27:22: <log-redirect v='false'/>
03:27:22: <log-rotate v='true'/>
03:27:22: <log-rotate-dir v='logs'/>
03:27:22: <log-rotate-max v='16'/>
03:27:22: <log-short-level v='false'/>
03:27:22: <log-simple-domains v='true'/>
03:27:22: <log-thread-id v='false'/>
03:27:22: <log-thread-prefix v='true'/>
03:27:22: <log-time v='true'/>
03:27:22: <log-to-screen v='true'/>
03:27:22: <log-truncate v='false'/>
03:27:22: <verbosity v='5'/>
03:27:22:
03:27:22: <!-- Network -->
03:27:22: <proxy v=':8080'/>
03:27:22: <proxy-enable v='false'/>
03:27:22: <proxy-pass v=''/>
03:27:22: <proxy-user v=''/>
03:27:22:
03:27:22: <!-- Process Control -->
03:27:22: <child v='false'/>
03:27:22: <daemon v='false'/>
03:27:22: <pid v='false'/>
03:27:22: <pid-file v='Folding@home Client.pid'/>
03:27:22: <respawn v='false'/>
03:27:22: <service v='false'/>
03:27:22:
03:27:22: <!-- Remote Command Server -->
03:27:22: <command-address v='0.0.0.0'/>
03:27:22: <command-allow v='127.0.0.1'/>
03:27:22: <command-allow-no-pass v='127.0.0.1'/>
03:27:22: <command-deny v='0.0.0.0/0'/>
03:27:22: <command-deny-no-pass v='0.0.0.0/0'/>
03:27:22: <command-port v='36330'/>
03:27:22:
03:27:22: <!-- Slot Control -->
03:27:22: <max-shutdown-wait v='60'/>
03:27:22: <pause-on-battery v='false'/>
03:27:22: <pause-on-start v='false'/>
03:27:22:
03:27:22: <!-- User Information -->
03:27:22: <machine-id v='0'/>
03:27:22: <passkey v='********************************'/>
03:27:22: <team v='32'/>
03:27:22: <user v='audioaficionado'/>
03:27:22:
03:27:22: <!-- Work Unit Control -->
03:27:22: <dump-after-deadline v='true'/>
03:27:22: <max-queue v='16'/>
03:27:22: <max-units v='0'/>
03:27:22: <next-unit-percentage v='99'/>
03:27:22:
03:27:22: <!-- Folding Slots -->
03:27:22: <slot id='0' type='SMP'/>
03:27:22:</config>
03:27:22:Trying to access database...
03:27:22:Successfully acquired database lock
03:27:22:Enabled folding slot 00: READY smp:4
03:27:22:WU01:FS00:Starting
03:27:22:Started thread 3 on PID 23263
03:27:22:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /home/audioaficionado/.FAHClient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a3.fah/FahCore_a3 -dir 01 -suffix 01 -version 701 -lifeline 23263 -checkpoint 15 -np 4
03:27:22:Started thread 4 on PID 23263
03:27:22:Started thread 5 on PID 23263
03:27:22:Started thread 7 on PID 23263
03:27:22:Started thread 6 on PID 23263
03:27:22:WU01:FS00:Started FahCore on PID 23271
03:27:22:Started thread 8 on PID 23263
03:27:22:WU01:FS00:Core PID:23275
03:27:22:WU01:FS00:FahCore 0xa3 started
03:27:22:WU01:FS00:0xa3:
03:27:22:WU01:FS00:0xa3:*------------------------------*
03:27:22:WU01:FS00:0xa3:Folding@Home Gromacs SMP Core
03:27:22:WU01:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
03:27:22:WU01:FS00:0xa3:Preparing to commence simulation
03:27:22:WU01:FS00:0xa3:- Looking at optimizations...
03:27:22:WU01:FS00:0xa3:- Files status OK
03:27:22:WU01:FS00:0xa3:- Expanded 3815742 -> 4169088 (decompressed 109.2 percent)
03:27:22:WU01:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3815742 data_size=4169088, decompressed_data_size=4169088 diff=0
03:27:22:WU01:FS00:0xa3:- Digital signature verified
03:27:22:WU01:FS00:0xa3:Project: 6096 (Run 8, Clone 36, Gen 19)
03:27:22:WU01:FS00:0xa3:Assembly optimizations on if available.
03:27:22:WU01:FS00:0xa3:Entering M.D.
03:27:27:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
03:27:27:Started thread 9 on PID 23263
03:27:29:WU01:FS00:0xa3:Using Gromacs checkpoints
03:27:29:WU01:FS00:0xa3:Mapping NT from 4 to 4
03:27:32:WU01:FS00:0xa3:Resuming from checkpoint
03:27:32:WU01:FS00:0xa3:Verified 01/wudata_01.log
03:27:32:WU01:FS00:0xa3:Verified 01/wudata_01.trr
03:27:32:WU01:FS00:0xa3:Verified 01/wudata_01.edr
03:27:33:WU01:FS00:0xa3:Completed 37075 out of 500000 steps (7%)
03:41:08:Server connection id=2 on 0.0.0.0:36330 from 127.0.0.1
03:41:08:Started thread 10 on PID 23263
03:41:09:Server connection id=1 ended
03:53:31:Server connection id=3 on 0.0.0.0:36330 from 127.0.0.1
03:53:37:Started thread 11 on PID 23263
03:53:42:Server connection id=2 ended
03:53:58:Started thread 12 on PID 23263
03:53:58:Server connection id=4 on 0.0.0.0:36330 from 127.0.0.1
03:53:58:Server connection id=3 ended
03:55:58:Server connection id=4 ended
03:55:58:Server connection id=5 on 0.0.0.0:36330 from 127.0.0.1
03:55:58:Started thread 13 on PID 23263
03:57:24:Server connection id=6 on 0.0.0.0:36330 from 127.0.0.1
03:57:24:Started thread 14 on PID 23263
03:57:33:Server connection id=5 ended
04:08:07:Server connection id=7 on 0.0.0.0:36330 from 127.0.0.1
04:08:07:Started thread 15 on PID 23263
04:08:08:Server connection id=6 ended
04:08:25:Started thread 16 on PID 23263
04:08:25:Server connection id=8 on 0.0.0.0:36330 from 127.0.0.1
04:08:41:Server connection id=7 ended
04:17:45:Server connection id=9 on 0.0.0.0:36330 from 127.0.0.1
04:17:45:Started thread 17 on PID 23263
04:17:45:Server connection id=8 ended
04:20:54:Server connection id=10 on 0.0.0.0:36330 from 127.0.0.1
04:20:54:Started thread 18 on PID 23263
04:20:54:Server connection id=9 ended
04:24:31:Server connection id=11 on 0.0.0.0:36330 from 127.0.0.1
04:24:31:Started thread 19 on PID 23263
04:24:31:Server connection id=10 ended
04:27:13:Server connection id=12 on 0.0.0.0:36330 from 127.0.0.1
04:27:13:Started thread 20 on PID 23263
04:27:14:Server connection id=11 ended
04:29:08:Server connection id=13 on 0.0.0.0:36330 from 127.0.0.1
04:29:08:Started thread 21 on PID 23263
04:29:08:Server connection id=12 ended
04:29:41:Server connection id=14 on 0.0.0.0:36330 from 127.0.0.1
04:29:41:Started thread 22 on PID 23263
04:29:53:Server connection id=13 ended
