60mm to 120mm converter
JaY_III
Senior of BX
your local hardware store.
get a furnace duct.
My buddy has a 120mm fan on a Globewin FOP38 HSF
JaY_III
Senior of BX
you have to mount the fan at a distance when you do that mod.
If it is too close, yes the deadspot will hurt cooling.
But if you have some distance the air is able to make it to the center....
You have to give the duct time for the "Funneling" of air to work
rlemieux
Cyber Deal King
The Big Easy
dont you mean you have a 80mm fan? Thats what the Swiftech uses. And btw you can get a 80mm to 120mm from www.plycon.com for about 16-17bucks US.
And about the Dead spot, I emailed plycon and swiftech and they both gave me the same answere. It does restrict flow, but if you have a 100CFM+ fan it will perform just as good if not better than the 80CFM Delta.
CyberFed
CyberFed
i think im going to go with another delta 80mm (i messed up and put 60mm) that moves 80cfm and a 120mm at the bootom of the case blowing the hot air off the area so that it doesnt get sucked back in with the fan, i also have 6 80mm fans that i'm going to use to cool the agp/pci/mobo area and also for exhust, so i think that'll be nice, i'll post temps when im done
