64bit vs 32bit
TorqueRanger
Is there any real difference in gaming or such when using 32bit compared to 64bit ?? Cause the problem comes as I lost my win7 64bit version and still have my win7 32bit version.. My laptop is maxed out at 4gb of ram and my main gaming rig has 8gb Gskill sniper ram..
wagex
Chapstick Eating Premium Member
there are quite a few games that will complain about not enough video memory if you are running a 32bit OS no matter how much video memory you have.
JLK03F150
What have I done! Member
Georgia
Did you lose the 64 bit disk or the key? If you still have the key, you can down Win10 64 & use it.
BoundByBlood
Maybe Something Cool?
MS Gulf Coast
Yes, there is a difference not just in gaming but in general with system performance and overall speed.
Machines with 32 bit cpu's and 32 bit version of windows are limited to 4GB of ram. On a system with a 64 bit processor and windows x64 no such limitation exists. If you plan on upgrading or eventually on building a more powerful rig someday go x64.
c627627
c(n*199780) Senior Member
Programs, single program, usually do not use more than 4GB of RAM... They are mostly not 64-bit. So this is about using programs specifically made to use more than 4GB. Check out that list to see which ones do.
64-Bit helps with multi tasking but not when using single programs which are mostly 32-Bit anyway.
