- Jan 29, 2009
I'm fighting to try and make a sandisk micro sd card that was in my phone for some years now work.
It won't write on the second dye of the memory chip I suspect at 29. Something gb free it's suddenly become unable to write or format.
I've tried to format it in the phone, pc, computer management, cmd prompt, sd formatter program and with rufus. also tried writing a new string in regedit to turn off write protect.
Currently trying to format it in cmd after being unable to delete the partition or gain access to the 16mb master boot record partition.
I can read the files on it just fine and I can delete files with file commander on Android but it won't write or format.
So if you've got anymore ideas other than grab a ticket and get in line with sandisk for a replacement...
Maybe it's just toast
Hack now? Y/N
Hack now? Y/N
