Hi Everyone,
First time posting here and new to Overclocking. Hi! Did some reading on other threads and learned quite a bit already. I have a few questions (specs at bottom):
I have been playing around with voltages but figured I'd finally leave on auto to see what I could get. I plugged in 4.6 GHz and got a stable OC of 4.6 GHz with memory under running at 2400 MHz (I have memory rated for 2666 MHz) with voltages around 1.35V and acceptable temps using OCCT, Real Bench, and IBT. I'd like to push my memory up to 3000MHz but I lose system stability at 4.6 GHz without touching the voltages. In general, should I leave the CPU voltage on auto or set it manually? Is running at say, a steady 1.35V better than leaving it on auto? I know I need to stay below 1.4 V but I do wonder because I'd like to save power, prolong the lifespan of my mobo/CPU, and reduce heat (I'm using an H80i V2). That said, consistent sharp increases in voltage probably aren't good either, are they? Should I consider adaptive or offset modes? How do those work?
Would I gain more performance if I dropped my CPU frequency and then increased RAM speed? Here's a hypothetical example:
case a) 4.6 GHz with memory underclocked to 2400 MHz
case b) 4.5 GHz with memory overclocked to 2600 MHz
case c) 4.4 GHz with memory overclocked to 2800 MHz
What would give me the best overall performance increase?
I know that memory runs on it's own voltages...if I can get a stable 4.6 with my memory at 2400 MHz, what would I need to adjust to give my memory more voltage? Just out of curiosity, what would be considered a safe voltage limit for memory? I don't plan on going crazy but it'd be nice to know.
Thanks for any constructive advice and guidance!
Mr. Gisa
(Comp specs)
CPU - Intel core i5 6600k
Mobo - Asus Z170-A
RAM - 16 GB G.Skill 2666 MHz
PSU - Antec High Current Gamer 900 W
O/S - Windows 10
Case coolers - 2 200 mm corsair air fans, 1 120 mm corsair air fan
GPU - Asus GTX 1060
CPU cooler - Corsair H80i v.2 (~130 mm rad with 2 120 mm air fans)
Mr. Gisa
(Comp specs)
Mobo - Asus Z170-A
O/S - Windows 10
GPU - Asus GTX 1060
