Hi,
I recently installed 6700k with noctua nh-u12s. I'm monitoring the temperature and hwmonitor shows 25-30C in idle and max temperature in load 71C. Realtemp shows few degree less. What is common for both is that one core in max is about 5C hotter than others. These temperatures are fine for me however I expected better results from this Noctua cooler. Am I wrong with this expectation? Switching new thermalpaste from noctuas to arctic 5 might do the trick. Paste applying methods are also on table for infinite discussion
What do you guys think of these these temps? Ok or should I doublecheck paste and mount? Paste is not visible while cooler is mounted so there should not be too much of it.
BTW
Is hwinfo for osd a good choice for cpu and gpu temperature monitoring, mean osd. Fan speed would be also nice to know.I dislike checking them via windows button
Thanks!
BTW
