6800 GT fan control? HELP!
mrgreenjeans
Cleveland, GA
Check the fan for obstructions. Mine barely makes a whisper, but of course I'm coming from a 5800Ultra that would put a Hoover to shame. Also my temps aren't near that high, more around 47-49*.
bobmanfoo
Disabled
leave it alone, the stock HS can use all the cooling it can get, just wait until the NV Silencer 4 comes out ;)
Nandro
Disabled
Wherever I happen to be.
Not really, my GT is pretty quiet. The vga silencer should be quieter though. Probably just what you need. Water cooling isnt always for overclocking. Some people use it because its silent. My zalman reserator makes absolutely no noise at all.
bobmanfoo
Disabled
AcUaViVa said:
your GT spining fan at the same rpm all the time?
what are you ambient temp ? ( drivers say it )
well i can hear my GT pretty well, its the loudest component in my rig now that im WCing
