6800K vs 9590
caddi daddi
Godzilla to ant hills
just how badly should my little bees new 6800K rig @3.8 crush my 9590 rig @4.8? because it's really crushing it badly.
Woomack
Benching Team Leader
If I'm right then you should be happy :p
I have my 6800K on cryorig AIO @4.2GHz 1.22V but above that it's not scalling good. It's more than enough for what I'm using it anyway :)
caddi daddi
caddi daddi
from what I can tell so far 4.0 will be the real number with this cpu, I'm trying to figure out the wire management while looking into weather or not this thing is trying to overheat and why.
I'm getting into the low 90's under prime95 at 1.1840 on the cores at 4.0?????????
while typing this, the bozo light came on..........
caddi daddi
caddi daddi
why is it that when the bozo light goes off in your head, it's right?
caddi daddi
caddi daddi
it is holding it in place Mr.Scott but the housing seems to be out of balance!!!!!
caddi daddi
caddi daddi
under aida64 it peaks at 55c at 1.126 @4250 now. so time to cleanup more wiring!!!!!!
