-I'm going to state up front that I'm not a fan of OCZ, so take this with a grain of salt.
"A lot of what makes Sandforce drives perform so well comes from data compression. For example, if I write a large, originally uncompressed file to the drive, it’s easy for the controller to compress this type of data. On the flip side, a ZIP file is already compressed, and consequently cannot be easily made smaller and therefore takes longer to write to the drive. Your computer still thinks that a xx MB .doc file is being written as xx MB, but once that data hits the controller, it ideally ends up as half that value. This compression helps lower write amplification and extend the life of the drive by using fewer program-erase cycles."
Okay all that right there pretty much puts this squarely into an OS drive position. I have a couple of drives in my system, and on my non-OS drives there lives a high amount of non-compressable material, rar's, video, pics, audio.
So two questions:
1. Am I really getting the space advertised on the drive? IE, is a 120G drive really close to 120G (I know there will be data loss to overhead, formatting, backup sectors ect..). So an 80+ gig rar file could fit on it right?
2. Is this the direction all SSD's are going to take? The only market I really see for the 120+ gig drives is in laptops. Most can only handle a single drive, so if you need speed and storage then bigger is needed. In a desktop machine an SSD and mechanical drive work fine as a team. (Obviously when speed is important such as video/photo editing or if you are an avid gamer, SSD's are better.) As an OS drive it's great, but I see this compression thing as a real limiting issue depending on how it is marketed.
