- Dec 19, 2005
- New York
Ok guys, RATTLE, DMAN, etc. etc. Maxi,
I have been out of the ATI game for ages, my last card was a 4870X2 at stock clocks. But I do have experience with overclocking, my last attempt at gpu overclocking was my old Viper John 8800 GTX with chilled sub zero water/antifreeze. lol
My new setup is: 2 X Radeon 6970's
Now, how do you recommend I overclock these? CCC?
I tried using CCC and overdrive, and any time I put the power control on 20%, and even put the cards on a minor 920/1400 OC, the cards will just shutdown windows and crash the PC. I have tried so many different things,
The only things that works currently is: 0% PC, 915/1375 - works
My GOAL: I am looking for the highest OC with both cards for a stable 24/7 daily overclock with NO NOISE from the fans. This would be a "set it once and forget it" OC
Thanks in advance guys!
Dom
UPDATE EVERYONE!
Couldnt wait until tomorrow. I have some good news. I took everyones recommendation and completely disabled CCC Overdrive and downloaded MSI Afterburner 2.0 from the MSI website. Immediately the card feels better and more stability and room. Right off the bat, I adjusted my fan line chart to idle at 38% below 45*C, and ramp up to 50% at above 58*C, 70% fan at 70*C, and 92% fan at 85*C or above. Already the card has blasted through 10 loops of Crysis Warhead Benchmark ambush, 8XAA, 1920 X 1200, Enthusiast averaging 78 FPS at 920 core / 1400 mem!! WHICH IS ALREADY HIGHER THAN I HAVE EVER BEEN WITHOUT CRASHING BEFORE. It definitely seemed to be a driver issue because with CCC Overdrive, sometimes the cards would crash before loading the game up just from the 2d to 3d switch. I am very happy right now. Going to try and max out the 950 core in a little while. Guys is there any way you can go higher than the frozen core/mem maximums in MSI Afterburner??
Thanks in advance!
Dom
WELL THERE WE GO! 3 LOOPS WARHEAD SAME SETTINGS 950 /1400 PASS!
60*C max temps with 45% fans at that temp.
Guys how we looking? Is there any way to increase the core beyone 950? Because it shows a max of 950 core.. Anyway to break that maximum?
And what about memory speed guys? I heard it is very difficult to clock after 1400 mem, should I just stick to 1400, or try to clock higher on the mem also?
Thanks guys,
Dom
Dom
UPDATE EVERYONE!
Thanks in advance!
Dom
Thanks guys,
Dom
