7500 questions...
attack
Does a 7500 with DVI and VGA outputs able to do dual monitors?
Also does the moblie 7500 with say 32mb memory able to run CS at 800x600 on a laptop...say 1ghz+ cpu?
what about the 9000 with 32 or 64?
Th0r
England. Liverpool, Aintree
First Answer..... Yes it can...
Second Answer..... Yes it can easily....
Third Answer.... The 9000 Would be an improvement over the R7500 in 32 or 64MB versions.... Plus it has DirectX 9 while the R7500 is only DirectX 7.......Go with the R9000 :)
Dc5e
MA
also, the mobility 9000 32mb has a 64-bit memory bandwith while the 64mb has 128-bit memory bandwith. So it may be worth it getting the 64mb version
