75Mhz Bus speed for ASUS P/I-XP55T2P4 Rev 1.4 M/B?
expatnl
On revision 3 and later versions of this board you could adjust the bus speed from 66 Mhz to 75 or 83 Mhz, but can you also do it on the earlier Revision 1.4 of this board. I've tried contacting ASUS but without success. So does anyone out there know if this board can be overclocked or not, and if yes, how do you do it ?
Thanks.
Sending email to Asus is a safe way to get rid of any sensitive information in your box. It's better than a black hole!
This mainboard is still listed at Asus. Just read all the info on it that you can find, and see what the various Bios updates claim to fix. The manual for this mainboard is a good one, if you can DL it, do so.
