Short back story this is a new build minus the power supply which is about 3-4 years old.
This machine when at stock clocks and up to 4.6ghz with adaptive voltage functions with no problems with XMP enabled.
The problem I'm having once I get to 4.7 and start adding voltage it starts to randomly restart no blue screen, crash nothing like I hit the power switch.
Now I thought maybe XMP was the problem so I turned that off same thing.
The only thing I can think of now that might be the issue is the power supply itself, I thought maybe the OCP was triggering so I split up where everything was plugged in on the PSU. Same issue.
When I do stress testing with ROG Real Bench, x264 Stability AIDA64 all come back passed it's only when the system has limited or no activity that this occurs.
System Specs:
7700K
EVGA Z270 Classified K
2x Samsung 960 PRO M.2 drives
Seasonic 1000watt PSU
NVIDIA 1080 Ti
I'm using a full water loop with 2 XSPC radiators and 16 fans in total. Also using EK Water blocks on the CPU & video card.
Temperatures have never gone above 70 when overclocked to 4.7 @ 1.27v
The only thing else I can think of is the PSU can't handle the higher overclock or I just got a bad chip in the batch. Has anyone else maybe had this occur before or can offer some insight into something else to check? Or am I on the right path as it is thinking it's the power supply?
System Specs:
7700K
NVIDIA 1080 Ti
